Windows Up/Down from Key fob
I was reading on another mustang forums website and it people said they can make there windows go down by holding the unlock button. Some Mustangs do it some don't? And if it doesn't you have to have a ford dealership turn the feature on. Can someone explain this to me, how it works and my 2007 Mustang doesn't do it.
Here is the link to the forum:
http://www.allfordmustangs.com/forum...ettings-3.html
RE: Windows Up/Down from Key fob
It's this and the new ones don't have that feature.
Window, Global Open/Close
The smart junction box (SJB) sends a defined pulse signal on the global open/close circuit to both door window motors to open or close the windows based on a signal received from the remote keyless entry (RKE) transmitter, door key cylinder or convertible top switch (if equipped). If the accessory delay relay is active, the global open/close feature will not operate. The global open/close feature is only available on vehicles equipped with perimeter alarm and built before 1/3/2005. This feature is not configurable.
+1....My build date is 12/15/04, and it is activated and works like a charm.... Now, if they had only let the early builds activate auto lock on manuals.....[8D][8D] Just on chance, I have gone through the process, gotten the correct horn chirps, but alas.....will not activate.....[:@][:@]
Mike
Mike
ORIGINAL: mlcrycc
Mike
Mike
Off subject, kinda -
Trunk Release to Windows UP mod
https://mustangforums.com/m_3636728/tm.htm
Electric Window insanity
https://mustangforums.com/m_3628917/tm.htm
lincolnshibuya
12-08-2015 04:37 PM
logan409
09-26-2015 07:43 PM
