Which oil to use?
RE: Which oil to use?
also being a previous turbo 4 cylinder owner and doing plenty of research on which cars like what oil, i found out that subarus want conventional oil, whereas my Srt-4 wanted mobil 1 synthetic.....which is another reason why i posted this, as i uncomfortably know very little about this car so far.....
I need an answer guys, how often do u change ur oil and oil filter on a DD?
Because I only change them every 5000 miles when I take my car in for maintenance, so I'm afraid it should be more often, like every 3000 or so!!
Any input would be appreciated!!
I'm sorry for jacking the thread, but u got what u want and since the question is related i figured i shouldn't make a new thread.
ORIGINAL: rshamekh
ORIGINAL: mcburns36
no
no
back on topic, I myself use mobil one 5w20 and mobil one filter and stick to the 3mos/3K mi interval because I romp on my car every day (after warming it up to normal op temp of course)...
Eh. Studies show that Mobil 1 does not break down, so technicaly speaking, you can go 1,000,000 on an oil change with changing the filter.
(this was a study done through my dad's work)
But go 3-5 thousand between, just to be safe
ORIGINAL: 22kart22
ORIGINAL: wadman
I switched to the Castrol syntech. It seems make my motor run smoother. Maybe its just in my head but it cant hurt the motor, so give it a try.
ps mobil one 5w30 is the factory fill for corvettes and the recommended service interval in the owners manual is 15K mi
thanks for all the input guys i really appreciate it...one more thing....i had knee surgery 6 weeks ago and i havent been able to drive the car, so its been sitting in the garage this whole time....should i change the oil before i take it back out because its sitting so long? or is 6 weeks not enough time for the acids in the oil to build up? Thanks again.
