Stupid Tuner question
I was looking at the diablosport Predator tuner, I have 2007 GT and when I was on there website I was looking at canned tunes that are included, and they have changed from 2006, which make perfect sense to me, what are the Performance 95mm MAF tune and the 2.73 pulley/ 95mm MAF tunes Here are the tunes taken from their website:
In 2006 they were:
Performance Tune for87 octane
Performance Tune for 91 octane
Performance Tune for 93 octane
In 2007 they are:
In 2006 they were:
In 2007 they are:
RE: Stupid Tuner question
It comes with a lot of tunes preloaded. A few tunes for higher octane fuels on a stock car, tunes for higher octane fuels with most of the major intake makes, and some tunes for a few intakes running nitrous.
IIRC, it doesn't come with any 93Octane tunes, only 91Octane. But if you look around on their support forum there is a post that tells you how to advance the timing for 93Octane.
If you're buying one, just remember that the U7140 is for 2005-2006 Mustangs, and the U7145 is for 2007-2008 Mustangs. The U7140 WILL NOT work with 2007+ Mustangs.
I found out the hard way that I need the U7145, thanks for the warning. Nowthe 93 Performance octane tune makes sense to me. But what at the other 2 advertised tunes used for? Those tunes being the Performance 95mm MAF tune and the 2.73 pulley/ 95mm MAF tune
ORIGINAL: smythge
The 2.73pulley isfor the GT500, the only pre loaded tune used on the GT would be the 93 octane, to get the 91 & 87 performance tune I have to use the tuner to back off the timing. Besides the timing being adjusted in the performance, does anyone what other "performance" adjustments have been made?
ORIGINAL: acascianelli
The 2.73 pulley tune is probably for the GT500.
ORIGINAL: smythge
ORIGINAL: smythge
I don't know, you might have to contact Diablosport on that one. I know that the throttle response is improved, it removes most of the throttle lag that the stock tune has.
ORIGINAL: rshamekh
Don't waste your money.
Go for a custom tune.
You'll need the tuner, to load a custom tune...
ORIGINAL: rshamekh
And get an intake with that (JLT or C&L)
ORIGINAL: rshamekh
Yeah, I know that. But why not get the tuner from a custom tune provider (Bama or Brenspeed ...).
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
