HELP !! The engine rev won't come down
Lately my car seems to have developed a strange behavior.
Not too long after installing my CAI and tune I noticed that on the higway if I let the throttle go my car would not slow down ! It was also the same thing if I was slightly going downhill the wouldn't slow down it would accelerate.
Yesterday I noticed that if i'm cruising at a certain rev (les say 2000 rpm) and I put my car in neutral, without touching the clutch (by slighly accelerating and pulling the shifter in neutral) the car rev will remain at 2000 rpm for ever, even if I'm stopped, it's only when I press the clutch that it will come down.
So after seing that I went back on the highway were there is a long downhill slope and tried this, if I let the throttle go the car won't slow down but if I press just very slightly on the clutch (not too much otherwise it fall free) the car start to slowdown.
Anyone have had this issue or any idea what it could be ? I have tried re-flashing the tunes and tried different one, but no change !
Thanks
Thanks
RE: HELP !! The engine rev won't come down
You guys are right, I have now narrow it down to the tune.... [/align][/align]The problem is that it's my B A M A tunes seems to be the issue, I went back to my original Demolet and it doesn't do it. [/align][/align]If I put either my 91 performance or 91 torque tune from B A M A the problem comes back.
Any one with B A M A tunes in here having problem like this ?[/align]
if your problems started exactly when
you put in the dali b a m a 's tune(s), then
i would say it's the tune.
if it started to develope over time, then
i would look at something like the throttle
body and maybe it just needs cleaning
hey thanks for the heads up.....how's
this for starters
overtime post
this for starters
overtime post
ORIGINAL: lldsandsll
i just noticed hammeron, you're about 1200 post behind howarmat...better start putting in some overtime.
TfcCDR
09-14-2015 12:08 PM
