STS Single Turbo Install pics
#22
RE: STS Single Turbo Install pics
I know this is an old thread, but it's the best I've found. Simon, at what rpm do you start to build boost? At what rpm are you at full boost? I'll be installing my STS twins within the next ten days, and am looking to get an idea of what I'll be driving. I really like that y-pipe. I'm thinking I might replace the factory H-pipe with an x, but for now, I just want to get it installed and drive it. All of my gauges and electrical goodies will be hooked up this weekend.
#23
ORIGINAL: breathegood
With DRs it's not an issue.
#24
Nice. I wish it would quick frickin snowing here so I could drive it. I can't wait. My S/CTacoma is fun and all, but thisMustang is going to rip. Are you using the electronic boost controller that STS sells, or are you using something else?
#25
I have a GReddy Pro Spec B. It works great. They make one more that is a tad bit more expensive.
There's some other guys here with others too. I use mine as a boost gauge also.
#27
Do you have any pics of how you have your Greddy mounted? I'm not a big fan of having a bunch of different gauges all over the place. Are you using a wideband AFR gauge or do you trust the initial tune from your tuner? I've got a pyro and a boost gauge, but I'm still undecided about the wideband. I have one on my truck, and it was useful while I was tuning, but beyond that, I think it's not a very aesthetically pleasing or particularly usefulgauge, and I would rather not have it displayed all the time. If I'm running lean in a dangerous way, the pyro will let me know.
#28
The Boost Controler (BC) is mounted in accesory lights on the headliner. This is directly above the center cosole where the two interior lights shine down into the seats. The lights are colored blue and it fits directly in there witht some massaging, a dremel tool and some finesse.
I do not have a pic of it right now, but I can take one and post it later.
The wideband is an AEM piece and works great.It's mounted on a two gauge pillar pod that looks OEM, below an Autometer tach/shift light. At first I thought it was junk because it would bounce around like it was broken. After I read about widebands, I learned it only matters what it says while under boost and while in "Lambda" the bouncing around is normal. On the low boost setting, 6.3-6.4, it starts at A/F 10.9 and then goes to 11.5~. On high boost, 9.3-9.7, it starts out at 10.9 and then jumps to 11.4, finishing at 11.8, which is supposed to be exactly where I want to be.
The car really isn't custom tuned for now. I need to data log, send it out and have someone adjust it slightly. Before I do this I want to take out the CMCPs so I can get it done aqt the same time. I'm running a safe tune with zero issues.
Except for using more gas!!!
#30
In order for me to switch I will have to get rid of the MAFIA and buy a new MAF.
