Super Charger Done... Now What??
#24
RE: Super Charger Done... Now What??
No I had et streets It did get rid of my wheel hop I havent had much track time because of issues that i came across from changing my trans to a 6 spd so I m going tonight to run . I'll see what happens .Two weeks ago I ran 12.32 with street radials but my 60 foot wasin the 2s and was loosing boost had two bad clamps. still my mph was 119 and 120.
#25
OK, here's a good start. Rear suspension: new anti sway bar and urethane bushings, adjustable upper and lower control arms with urethane bushings, adj. panhard rod,springs, shocks and anti squat brackets. Frontsuspension: springs, struts, urethane sway bar bushings. Driveline: engine torque limiter, one peice driveshaft and loop, & axles if you want to.. Brakes: 14" fronts, stainless lines, racing fluid, rear high performance pads. There's lots more if ya want to get crazy! Are you sorry you asked?
#28
That's the most logical post you have ever made in here! Thank you!
ORIGINAL: ohnoesaz
invest the remaining money into a simple account that pays 5.5% interest every year and adjust your investments in 3 years.
Or blow the money.
Or blow the money.
M3hunter
09-05-2015 03:42 PM
