Synthetic fluid in 5-speed manual
RE: Synthetic fluid in 5-speed manual
ORIGINAL: cavediver
I looked at the Tufoil web site but didn't see a tranny additive, only engine additives. Did you mix Tufoil with Red Line in the tranny? Which Red Line product did you use in the transmission?
ORIGINAL: algregory
Been a believer in RedLine Products for years and several hundreds of thousands of miles, two cars and a PU.
Mustang GT, 5 speed, has RedLine D4 in it. Used a 10% mix of "Tufoil" from www.tufoil.com Tufoil originally recommended to me by the machinist that custom built a modified BMW engine for me. I truly believe it shifts better, smoother, still "notchy" and not like a BMW trans. Redline says the fluid good for 30 to 40k miles. I put in at 3.8k, now have 24k and change, plan to change at 30k.
Moved to NC, Redline only available here by mail order. Hassle. Found a local Amsoil dealer, 25k oil change will be Amsoil, trans change at 30k will be Amsoil, motorcycle and PU will follow when it is time, Tufoil is used in all rides.
ORIGINAL: 5SPD07GT
anyone have a write up on how to do the fluids yourself?
BeatnikFink
10-01-2015 08:00 PM
09-25-2015 06:42 PM
