Removal of Fog light grille
RE: Removal of Fog light grille
Yes, if you can get a copy of the "How to" booklet on the install of the Roush Front Fascia...you will be able to remove the light grille...as this is part of the process. The instructions are available on the roush homepage..
I used this sheetwhen I put on my center fog grill before I did the GT500 front end conversion. Hope it helps. Just take your time and a friend wll help also. Make sure you have plenty of light.
http://www.streetsceneeq.com/instruc.../950-73595.pdf
Whoops! Sorry partner (Mellowyellow06)you were too fast for me, but your instructions will work too...
http://store.roushperformance.com/im...structions.pdf
ORIGINAL: TPony
+1.
Here's a link to a ton of PDF files for stuff like this....Comes in pretty handy......
http://www.2005stang.com/viewtopic.php?t=1087
It is pretty simple to remove the grill from the GT bumper. Basically pull off the radiator cover, and yank the grill out lol. The clips will put up a fight, I found it easiest to wedge a little screw driver inside the clip and ease it out.
not to jack this thread or anything but I have a question, I tried to take of my grill (2007 V6 pony package) and I could only get off the top clips. There were a few more on the bottom, how do I get to those or is there any easier way like just take off the bumper.
ORIGINAL: steveo555
Requires two people, but wht the hey. Watch the A/C
condensor and try and avioiding bending any fins on it.
JackHigh
