Idle RPM fluctuating...
RE: Idle RPM fluctuating...
Buy a new JLT filter....i bought a new C&L about 2 weeks ago......man the car drove like it gained 10 HP! Its not more than $40 for the new filter and you know it is oil correctly
Thanks guys...
Right now I'm leaning towards IAC. I'm going to mess with it tonight, maybe clean it, though I'll need an electrical cleaner of some sort.
I'm also thinking alternator maybe? Fluctuating RPMs + dead battery maybe? We'll see if this brand new battery dies quickly.
I'll get a new air filter, good suggestion. Don't like my competancy in my oiling skills.
Upstream O2 sensors, I might replace those soon. 2 x $45 at checkers. But I notice they are turned off in my b@ma tune, what exactly does that mean?
ANNNyyyyways thanks for all your help! It could be a jillion different things as we're discovering.
Have you checked the mass air flow sensor like somone suggested? If it's dirty it would do the same things. Afraid to touch the spark plugs because you don't want to break them? Okay mr lok-tite.
ORIGINAL: howarmat
upstream should not be shut off....they are the main sensors that the car needs....the downstream are shut off perhaps though
Also what is your a/f at idle during the hesitation. This info will tell me a lot. Usually spark plugs show there first signs of fouling on the big end and not at idle.
tHitting the gas while already going at normal speed doesn't have a problem or any hesitation, nor does hitting the gas at low RPM either for that matter
anyway, let us know
