Hood Pins?
RE: Hood Pins?
ORIGINAL: 2007Grabber
I have the CDC stick on ones and they look really cool until you open the hood.
Not drilled = waste of time IMO.
RE: Hood Pins?
ORIGINAL: KingofUSMC
I was going to ask the newb question. Is that what they are for? Keeping the hood latched or something? Or a combination of that and visual appearance.....?
RE: Hood Pins?
Aftermarket hoods use to be known for haveinf the stricker seperate from the hood and the hood flying up cause a lot of damge. I always use pins with aftermarket hoods. Especially with these winds we have had latelty. Just that extra reassurance.
RE: Hood Pins?
ORIGINAL: fordfanboy
Or until you actually need them from keeping your hood from flying off...
If they are working to keep your hood on - then somehow you have unlatched the hood and some defeated the safety catch. If the wind caught and jerked your hood past the safety catch then no hood pin in the world is gonna save ur hood or your a$$.
but, drill'em if you get them. even if for appearance, you might as well do them right, cause you will inevitably want to raise the hood.
RE: Hood Pins?
Got drilled ones here. Took about 2 hours to install because I kept remeasuring everything over and over to make sure I don't make a hole were I'm not supposed to. Got them because everyday on the way to and from work I go over 100 sometimes up to 140 and I'm worried about losing myhood.[&:]
P.S. Adhesive ones DON'T work.
RE: Hood Pins?
ORIGINAL: olvanish
