GT 500 Front Facsia....HELP....
RE: GT 500 Front Facsia....HELP....
Mustang Racing Tech...
www.mrt-direct.com
they do everything on mustangs..
and you can order everything you need there.
www.mrt-direct.com
Thanks for all the help Guys.....does anyone have an updated parts list including what nuts and bolts.and how many of each i need...just to make sure i have everything...
I hope thes are what you are looking for.
I have posted the parts list a couple of times in previous posts, but they are around everywhere. You wont need a rivet gun either. We just put the blinkers on and secured with a tie strap. Youl see what I mean if you get to that point and notice it will work perfectly. The bolts for the splitter on bottom can be purchased from a home depot. Just nuts and bolts and washers. You wont need the inner fenders either. You can just trim yours a bit to make it fit, very easy. And dont waste your money on the wiring harness. Just cut your GT fog wires and extend them and get some small connectors and it will fit like a charm.. It is really simple and actually fun as you see the car transform. Ill put up some pix of our transformation in a bit.
