Need Help With an Error Im getting about tire pressure
RE: Need Help With an Error Im getting about tire pressure
ORIGINAL: MrSandman
+1
+1
ORIGINAL: white531
build a pvc pipe,put the sensors in it. put40 lbs of air on it and put it in the trunk.Done.
ORIGINAL: 157db
+2
ORIGINAL: MrSandman
+1
+1
ORIGINAL: white531
ORIGINAL: ApexStang
So have you guys actually done this? Not to sound like an ***, but on another forum I heard people say that these things could potentially blow up and it's not a good idea to pressurize PVC pipe. I would like to see a photo of this contraption and how you actually were able to pump 40 psi in the pipe and how you keep the air in.
ORIGINAL: 157db
+2
ORIGINAL: MrSandman
+1
+1
ORIGINAL: white531
Here goes. Air in pipe via a schrader valve just like your tires.
Use Schedule 40 or 80 PVC. Schedule 40 is good to 150psi.
All PVC pipe of any quality has theworking strength printed
on it. It also has a bursting strength much higher than the working pressure.
Clean all PVC before gluing. Allow to dry overnight before
airing up.
I have used 4" SCH40 for my potato guns and it holds up to
the 125PSI that I use to launch taters. So 38PSI is no problem
for SCH40 PVC. Believe it or not......
ORIGINAL: vmaxman2
I'm confused. I changed my wheels to 18" Cragars and don't get any warning on the dash. I didn't reinstall the sensors. I wonder why.
or an 05-06 without the TPMS system?
ORIGINAL: theresa
Even though you push the button to reset the warning, you still have the other
warning light on the other side of the panel.
So what form does the warning take? The one that's not "the other warning light on the other side of the panel"?
Is the warning so obnoxious you can't stand it, or does it disable the car? If it's a light-only warning, what will it hurt to leave it on?
I understand American Muscle sells the bands for $16.95 or some such.
http://www.americanmuscle.com/universal-tpms-bands.html
I read somewhere the Ford set comes in at $59.95 per wheel.
I'm likely to be putting on new wheels and tires without bands or sensors, very soon. Unless the effect of no TPMS is pretty extreme, I'm not going to throw away several hundred dollars to turn off a light.
jwog666
12-27-2021 08:09 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
