Help: Replacing Brake Pads
RE: Help: Replacing Brake Pads
I have done this a number of times. The fronts are easy. You can compress the pistons in using a C clamp against the old pad. Takes no time at all.
The rears are much more of a PITA. They have two slots on the face of the piston which are used to screw the piston back in. You can get a universal brake tool that's a cube shaped thing you attach to a ratchet / extension.It looks like this:
This is an inexpensive solution and will cost you around $10-$15. Only problem is, none of the 'nubs' fit in the slots on the piston. But what you can do is take a grinder and on the side with 4 nubs, grind off 2 of them and the remaining 2 will fit, kind of. But not really. I tried using this tool and it kept popping out of the slots, scarring up the pistons, etc. So I abandoned it.
Instead, I bought a universal set like this one. It's a bit more expensive at around $50 for a cheap set like I boughtor $200 if you want the Snap On or Mac one. But it makes the job WAY easier. One of the circular adapters fits the slots perfectly and the brake-pad looking thing wedges in the caliper so the tool won't pop out while you turn it.
Good luck!
Kevin.
Good luck!
Kevin.
^^^ Bingo, that's the kit in the above pic.
No, it's not like a C-clamp at all, more like a key. It's cube shaped. The cube shaped tool is available
at any auto parts store, but there pretty cheap. You can buy a really nice kit that includes the special tools
for the rear brakes and the tool to compress the front brakes. Harbor Freight has a nice kit.
ORIGINAL: 05BlackPony
Thanks for reconfirming my understanding.
The tool for the rear calipers, is it just a C-clamp like tool, or is it a tool that acts like a "key" to lock into the piston? I watched an install on YouTube last night and the rear caliper on the car had an e-brake, (like ours) and required a tool to lock into the piston.
ORIGINAL: grampa_stang
Guarantee you're going to have to compress the piston to get the new pads on.
fyi: Frontpiston just pushes directly in
rear piston must be rotated in with a special tool.
ORIGINAL: wingman75
Why not install performance pads, like Hawk, while your at it?
- Thanks for everyones help! Very anxious to get some nice stopping power soon!
Hey 05BlackPony - can you tell us which Pads you are going to install? Once installed and tested please give us an update on how they work (if you are installing perfomance oriented pads I'd like to hear your feelings on the differences to stock). Thanks.
Harbor freight has the cheap kit on sale for $19.95, regularly $30.00, Autozone or Advance Auto parts lend them for free. The cube sucks. Keep an eye on your master cylinder as it can overflow and brake fluid will eat off paint. Pick up a turkey baster to take extra fluid out of master cylinder.
-Argonaut
I'm going to install Hawk HPS pads with RotorPros (Centric) Rotors Drilled/Slotted. Will let everyone know the results!
jmk3- Thanks for the heads up! I wouldn't want to pop the hood one day and see a chewed up strut tower!! []
Thanks again to everyone!
-Argonaut
-Argonaut
