Rattle at start up?
#31
RE: Rattle at start up?
Thanks for including the image. I brought a copy of it to the dealership, they put the bolts on in 5 minutes and the rattle is gone. I really appreciate the effort people make here to help each other out!
Thanks again.
Thanks again.
ORIGINAL: satinsilvergt
I attached a picture of where the missing bolts are. Of corse mine are there now. This should give you a better idea where to look.[IMG][/IMG]
[IMG]local://upfiles/12976/B2CE9939CCF94D71A3AF229661F63952.jpg[/IMG]
#32
NO problem... i forgot about this thread. lol....
Females shouldnt be stereo typed as Nontechnical.. Because some girls can hang with the best....
I thought the guy was nuts the first time he told me his "heat shields" rattled. lol. finally i found the noise and had to post in here ASAP. lol
Most of us get along.... But We all know im the 2005 Trouble maker... and i dont even own one. NEVER will either
#33
Hi Casper, I am a newbie here and wondering about this rattle.
ON my 2005 GT I hear this thrumming that feels like it is coming from the shift boot (manual tranny) so I put some lexol on the shifter boot thinking it was just not moist enough and was creaking. That didn't work. I was thinking that maybe it is the same noise, ths ony thing is it is not loud, but more of a thrumming in the first two gears, then it is gone.
Any help would be greatly appreciated.
#35
Lets see...... casper works for ford.... caspers good with wrenches.... caspers dont like 05 mustangs....casper was the first to point out missing bolts.... Is anyone else forming a picture other then me?
#36
its probably just back pressure that is built up when the engine is first fired up that is flowing through the exhaust causing it to rattle..that is why it goes away after a minute or so id imagine
#37
Casper,
I've got the same rattle described in the thread, but when I looked at the plate the bottom two bolts were installed. When I followed the plate all the way around I noticed on the drivers side of it, just above where you pointed out the bolt in your pic, there are two empty holes there. Should there also be bolts in those?
