question abou tperf. package
http://www.jmschip.com/shop/product_...roducts_id=334
what does the Charge Motion Plate Kit (IMRC Deletes) do??? thanks!
RE: question abou tperf. package
Have you done some research first for youreself. Or did you not even take anything to check it out? Because i could simply come on here and tell you what its for, but for some reason i dont think you researched it first.
Casper Casper... ... your just a tease..haha Bobby.... Charge Motion Plates are already on your car. They bolt between the intake and heads. The stock ones have flappers in each intake port that close off air under low to mid throttle. Under full throttle they open up completely. The ones Steeda sells have no flappers in the ports. They are straight through. They give you about 10 Hp in the low to mid RPM range but marginal at full throttle because the stock ports are open wide then. .. word [sm=bling.gif]
Fugger Yeah, what he said. They made their big debute on the DOHC engines. Making better flow at higher RPMS, also they like to carbon up alot and stick on you, weather its open or closed.
mungodrums
10-07-2015 04:01 AM
mungodrums
Suspension
09-07-2015 07:28 PM
