Suspension? Which is best
I read on one Mustang website that the H&R Springs were preferred. Most others prefer the Eibach. I had Eibach on my last car and loved them. Whatsthe best setup on the Mustangs? H&R looks like they have alot of choices that make it confusing. Also, does the camber plates need replaced after the new suspension?
Thanks
Thanks
RE: Suspension? Which is best
I went with the Ebich Pro Kit on my Stang and had H&R on my BMW. They are both good. The only thing I would say is don't go crazy low. My BMW was lower than my Mustang and I had to be careful everytime I parkedmy BMWnot to scrap the front facia.It gets expensive after a while.I have not bottomed out the Stang or scraped the front facia yet withtthe Pro Kit. I did not need the camber plates with the Pro Kit, tires are wearing perfectly.
ORIGINAL: dseid2
Thanks for the reply. Does the Eibach drop it to where the fenders are just above the tires? I don't want them to "tuck" up in the fenders.
I installed the TEIN 2" drop coils on mine and have no complaints. They work really nice with my 20's which are the same rolling diameter as stock. The pic below is before the 20's to give you an idea of the look with stock 18's. The one thing I do suggest is to get some caster/camber plates soon as there is no camber adjustment avialable with the stock struts unless you open up the bolt holes at the knuckle. Opening up the holes is cheaper but I really feel that the plates are a better investment. See Maximum Motorsports. You may have to endure the sound of the factory upper strut mounts 'popping' when turning if you drop it before getting the plates. Hope this helps.
[IMG]local://upfiles/83073/37EF5681934E4BD09CC05692E279894F.jpg[/IMG]
People will nearly always recommend the springs or handling pack they currently use, it's human nature.
I do think it's wrong to fixate on one manufacturer being head and shoulders above the rest. Issues like ride height and spring rates aren't down to the company, they are down to the selected spring, which is more down to the customer mis-spec'ing for the car. All of the big name suspension guys make kickass stuff, you just need to select the right setup for your car.
I will say though that just buying springs alone is often less than half the story. You need to match springs with shocks and also geometry, especially when you lower the ride.
Thanks guys for all your input, this does help in my decision making. I know y'all have read and answered these suspension, exhaust, and rims threads a thousand times. Like most have done, I searched and read threads that give me good information, just not the exact answer unless a new thread opens to ask. Thanks again guys for enduring another routine thread. [sm=smiley20.gif]
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
