Final numbers after motor build....
Man if I had that D-1 that punk would have made 650 easy with 60 lbs injectors....
Final number are 578rwhp 497 trq on the 39lb injectors. Thats all they would take but my car wanted so much more with those cams in there... Alot of more power to go when I get my injectors....
Heres a clip... Not the best..Its from my camera phone, but you can hear that bitch rap out quick as shi%
http://www.youtube.com/watch?v=HvUtTTx2Mas
RE: Final numbers after motor build....
Very Nice, my procharger fund is almost complete.
can you give us a lil info on your built moter, did you buy a strocker short block. Is it the 4.6L block the car came with what crank.....?????
ORIGINAL: NyFordTech
Procharged-H-Beam rods-Manley Piston-Comp Cams stage 4-Cobra Crank-GT 500 fuel system-Centerforce Clutch-BBK Longtubes-X- Pipe No Cats- 4.10s-39lb injectors-Mafia-BMR LCA-BMR Adj. Upper-Adj Panhard- Tokiko D-
I did not go with a stroker motor..... Just bought a new block and had it built... Im about to get a D-1 procharger and then it will be alot stronger then it is.. The 39 lb injectors are at there max point as it goes lean at about 6200.. So I have to watch it until I get some 60's..... Cant wait to got to the track...
What times do you think I will run... I have ET streets and was running 7.6s before the build on 8lbs of boost with 1.7 60fts....
