Fender without antenna hole?
Does Ford make a passenger side front fender without the cutout for the antenna. Since I have to replace my fender, I might as well do a antenna delete too. I think I found some on partstrain.com says fender without molding hole for $120, do you think it is the same thing as the antenna hole not cut out?
RE: Fender without antenna hole?
ORIGINAL: rtredline
If not im sure it would be fairly easy 2 modify the stock one and then paint it...
yeah, just order the stock one and tell the guys to weld a little patch into it before they prime it and paint it.
they might do it for free, but if not, shouldn't be more than 100 bucks.
No, it is not OEM available without the antenna hole.
Now for the aftermarket replacement fenders, they seem to come
minus the antenna mounting hole.
Try this neat do-able antenna delete by NELS GT in the mean time.
https://mustangforums.com/m_3973805/tm.htm
[IMG]local://upfiles/69445/E30E3D46FFC341138CD255BCA1D25D0D.jpg[/IMG]
ORIGINAL: luckydawg003
Large hole and three small hoes need to be welded in. Must be done by someone who has done a lot of thin sheetmetal welding. This sheetmetal is practically paper thin and is guaranteed to shrink/warp if you do not know what you are doing. Do that and you may have just ruined a perfectly good fender.
[IMG]local://upfiles/24316/0F9EF530179B4EE19E6C74884E53C01F.jpg[/IMG]
ORIGINAL: allj
It is if you are already getting it painted/repaired. One of the best mods that no one notices.
ORIGINAL: rtredline
jwog666
12-27-2021 08:09 PM
