Stangmods HIDs...Lo beams dont work?
Finally got the bulbs to go in, required trimming of tabs and modifying the gasket, but now only the high beams work... Any suggestions? I know someone had this problem but I dont have time to search right now... Thanks
RE: Stangmods HIDs...Lo beams dont work?
Im sure the time it took you to write this post you could have found it. Please search. The problem was not solved as it was figured it could have been a wiring harness or ecu programming. I would go with the wiring harness route and see what you can do about it. If anybody else has more info then by all means correct me. I think your going to have to do the research yourself as not many people have done this successfully yet.
hey infinity...how long have you been using this forum, been a member since august? well guess what I did search and couldnt find it, and was looking thru the results for a couple minutes with no luck. Then I posted this, I use search thoroughly, but I was late for work. So why dont you look who you're talking to before you go and tell me how long the search takes. Everybody else, thanks, and if anyone knows the answer lemme know!
