V6 Pony Grille Kit with Lamps
RE: V6 Pony Grille Kit with Lamps
ORIGINAL: Hubcapsplus
We are offering a Pony Grille package that utilizes the factory Ford Pony Grille in conjunction with set of aftermarket fog lamps and wiring for $179. This will save you quite a bit over the $500.00 Pony Grille kit. If you want to use the stock Pony / GT switch and wiring we have them available also at $65.00 for the switch and $85.00 for the Pony Grille wiring, relays and instructions. You can PM me or give me a call as these are not yet on the website (they will be up later this week.)
Got a pic with one installed?
Hi, sorry if my post was a bit confusing. Hopefully this may clear it up a bit. This is an actual grill not an overlay. It is the same grille that you would get from Ford if you purchased a V6 with the pony package. This grille is only for V6 mustangs. We have installed on this grille aftermarket fog lamps. What you get for $179.00 is the grille with the fog lamps already installed. We also include the universal fog lamp wiring and rocker switch that came with the lamps.
In a nutshell is it a full OE Ford replacement grille and fog lamp package for $179
Now for the options. We have available the wiring ,relays , switch, and instructions that come from Ford in the pony package kit.
The factory wiring with the relays is $85.00 and the factory switch is $65.00 .
I hope this makes a bit more sense.
can i ask how u got it for cheaper? lol are the aftermarket fog lamps different or better quality then stock? and are they blue lighting or white? just curious because i was going to buy the tints for the fogs to make them blue
The factory fogs have a glass lens and a built in adjuster mechanism, which makes them superior to any of the aftermarket fogs I have seen.
We are using a universal fog with a plastic lens, this is what allows us to offer these kits at a greatly reduced price.
For those of you that want a full Ford Factory Pony Grille kit we have them in stock also
http://wheelskin.com/6r3z15200aa.html
jwog666
12-27-2021 08:09 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
