HELP! Installing My HID's..
Ok so I ran into a problem while installing my HID's. Theyare plug and play. I connected the wires to the harness from the stock headlights and they work just fine, well only when the car is off. Once I start the car they flicker and turn off. They didnt come with wires to connect to the battery. I am thinking there is not enough power to run them. Can anyone help me here...What do I need to do, besides send them back lol. Thanks
Mike |
RE: HELP! Installing My HID's..
No help, but a question.... Why do people get HID's?
You need to disable the DRLs
What are the DRL's? And I suppose people get them cause they want brighter lights, maybe because they like the way they look. I got them because I have headlight and fog light covers and they dim my headlights so much, that at night I can't see. And I plugged the wire into the high beam and they work fine with the high beam on and the car running. Does that make any sense to you?
Mike |
DRL- Daytime Running Lights
Glenn |
no help, but why do people make stupid comments?
does the wiring harness have a relay? All HID systems for the mustang have to be connected directly to a relay and that connected to the battery. You use your headlight wire to activate the relay/Hids.
Hey what's up. Nothing about hid's. But did you get a chance to to try the dr's yet?
What did you do as far as time if you did? Thurman |
ORIGINAL: schapman does the wiring harness have a relay? All HID systems for the mustang have to be connected directly to a relay and that connected to the battery. You use your headlight wire to activate the relay/Hids. |
I was asking a legitimate question. I don't know the advantage of HID's unless you're headlights are tinted. Are stock lights somehow not bright enough??? Mine seems just as good as any other headlight I've ever had.
| All times are GMT -5. The time now is 01:55 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
