Questions on GT shorty install
I've read several online guides, but wondering if all of that work is needed... I'm posting an annoying amount of questions here in hopes this could also help people in the future.
1. Must remove motor mounts?
2. Must remove starter? (Assuming yes but still asking)
3. Must remove or move steering rack?
4. Ever have to turn wheels during process?
5. Torque settings for bolts/studs?
6. Copper RTV around new header's new gaskets?
7. Copper RTV where new header meets old cat-pipe?
8. Anyextra special tools the regular person won't have?
9. Any tips on where to reach forsome harder bottom bolts/studs?
10. Hardest thing to do during the entire process?
11. Add any tips here...
RE: Questions on GT shorty install
ORIGINAL: ohnoesaz
Yes 4 bolts on the block one to the k memeber
yes pass side
the rack stays, steering shaft has to come out
No
depending on what shorties you will have all new bolts no studs- 30 ft lbs
I didnt use it
Didnt use it
Its mostly hand tools no room for air, definetly get some ratchet wrenches
I tightened the 4 bottom bolts and then tightened the top 4bolts
Fully touqing every bolt tospec driving it and the re touqing as it said in directions
11. Add any tips here... I couldnt imagine doing this with out a lift it took me about 6 1/2 hours with a lift at work. I installed the bbk shorties ceramic coated, getting blown so long tubes really didnt matter to me. shorties are fine!
yes pass side
No
I didnt use it
Didnt use it
Thanks for your answers. Dang it sounds tough!
Im getting the BBK shorties also, "tuned length". This is what you got? How does the car feel afterwards and is there any sound difference?
Also... how did you do the motor mounts, considering you used a lift so its not like youcould jack the engine up?
bumping because im installing this tomorrow and want as much inside info as possible... trying to have a carefree install, even if it does take a really long time....
When I had my Shorties installed, the Mechanic, who is a friend of mine, and his two helpers all agreed, that IF they did this job again...the price would be much more than I paid. It really sounds good on the Web Site when you read it..."Simple bolt on, replaces your Stock Exhaust Manifold".........Yeah, Right
Shifty Magoo
08-25-2015 03:08 PM
