How do I turn off my DRL?
RE: How do I turn off my DRL?
ORIGINAL: tripc
They never came on before until I programmed a new remote... How do I turn them off. I hate when they come on after I let the E-brake down??
https://mustangforums.com/m_2470427/tm.htm
Is the switch itself a microswitch sort of thing, and if so, can it be shimmed, relocated, a tab bent, or something else done to reset its 'ON' pointsuch that the parking brake lever can be left all the way down?
Norm
Norm
ORIGINAL: tube
Keep the e-brake up.
the only thing to do is get the dealer to re-program or deal with it
if you got an aftermarket HID kit, then its easy to disable as you would just interrupt the power flow between battery and ballast with a seperate switch wired inside the cabin
DRL = FTL
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
