What would it take to stuff a 2004 Terminator engine in our cars?
I could get a 2004 SVT Cobra engine that pushes out around 650RWP for about 6 grand....
Anyway in hell to stuff this in a 2007 and have everything function properly?
RE: What would it take to stuff a 2004 Terminator engine in our cars?
ORIGINAL: CroDalmatinac
ORIGINAL: 05gtdriver
You'd be better off stuffing that Termie motor in a Fox body and go rip someone unsuspecting a new one. Not sure where you live, but in Cali you can't replace a car's motor with an older year of engine and be smog compliant. You'd be better installing a stroker(maybe $3500 including labor), then adding a supercharger( maybe $5,000) and you'll be strong and legal and trust me that $6K Termie motor after all the fabricating, tracking down parts to interface with the S197, then all the electrical gremlins that most likely will surface, you'll be past that $8K+ price tag...................
http://www.karkraft.com/new_engines.htm
keep you motor and build the s*** out of it...... my guess is that you would need to change the Computer ,harness and all that junk .... for the cobra motor
Yeah, don't even mess with that. This is what's going in mine when/if the current motor fails:
http://www.seanhylandmotorsport.com/...ngblocks.shtml
3V ALUMINUM BLOCK LONGBLOCK (2005-08 MUSTANG GT)
- Minimum Dress (no front timing components, camshafts)
- 05-08 Production Aluminum Block
- Forged Steel Cobra Crankshaft
- Manley H Beam Connecting Rods
- Manley Forged Pistons, Flycut for 3V (2618 high strength material)
- HD Molybdenum Steel Piston Rings
- ARP Main and Head Bolts
- FM Main and Rod Bearings
- CNC Ported heads, Beehive Springs, Stainless Intake Valves, Inconel Exhaust Valves
$8995 Outright, $7495 Exchange
Optional Components
- 3V Oil Pump, Pick Up Tube and windage tray $95
- HO Oil Pump w/Pick Up Tube, Billet Oil Pump Gears (requires aftermarket oil pan (Canton, etc))- $350
- Dowels, Pins, Rear Cover and oil seal $120
- Manley Billet CNC I Beam Rods - $800
- Race Bearings - $80
- Comp Cams Billet Camshafts - $720
Optional Components
$3000 worth of parts and $4500 worth of labor (counting porting). Not counting options.
These engines must be mighty complicated.
Hmmmm...... I wonder if a 514 BBF will fit?
