bmr lca's help if you have them
RE: bmr lca's help if you have them
I didnt even jack my car up to do the install, so when I tightened the bolts the car was fully on the ground.... Should be the right place to do it from? Still get clunking... Im not complaining, just saw the thread and joined in.
Did you jack the rear end up untill the shocks were back to that mark before going for torque? If not you probably have them bolts preloaded which is why your having problems.
ORIGINAL: techmanBDsStang
No problems with my non adjustables, and I do have the grease fittings on both the front and the rear of the LCA.
ORIGINAL: oshkoshbajawsh
i dont think there are any non adjustables with grease fittings on both ends...
Are you sure you don't have Tubular Lower Control Arms, non-adjustable, with polyurethane bushing and spherical bearing combination. Then it would just have one, where mine are the ones with bushings on both sides.
