Best way to lift our cars with a floor stand?
I'm buying one of those floor jacks that u pump and raises the car to swap my summer/winter tires easier and I was wondering if there was a place where i could put it to change two tires at the time, or where the best place to put it was? thanks!
RE: Best way to lift our cars with a floor stand?
I don't know what a floor stand is, but I use a large floor jack underneath the rear axle and under the engine cross member. Probably done it over 100 times with no problems.
Edgespeed - you can place it right under the differential and lift the rear end so both wheel are off the ground-- but be careful, some of the stock differential covers are lower than the differential itself so you can bend the lip and cause a leak. I have the LPW low profile cover on mine and I can see the edge of the differential, and couldn't see it with the stock cover.
ORIGINAL: edgespeeder06
can i ask why not the door grove? like i do with a regular jack? and how will i kno exactly where those places under the car are?
The arrow is where you put the floor jack and lke JimC said be careful of the cover in the back (you can see here that it is a little below the pumpkin). Use jack stands where you see the red dots on the axle shaft.
tho I did it once myself and lots of guys do it... Ford specifically says not to jack @ the pumpkin..... the Ford cover is very thin and easy to bend...
