PROCHARGER ISSUE
RE: PROCHARGER ISSUE
ORIGINAL: A1SALEEN
ok why is it drawing oil from the pcv?
You can use the stefs oil seperator Part number #5128
It has a 3/4 npt inlet and a 1/2 npt outlet which will save you some dough on fittings. With this one, you can use std. brass fittings from your local hardware store to convert the 3/4"npt inlet to a straight 5/8" barb, Then to convert the 1/2"npt outlet to a 90 degree 5/8" barb.
Summit Racing:
MOR-63401 3" can bracket 6.95
and your all set. Just need some 5/8" ID hose thats rated for oil/fuel and your good to go
Personally, Don't buy the junk Spectra hose. I changed up to -10an Earl's Perform-O-Flex hose and used their -12an to -10an adapters with -10an straight and -10an 120* fittings on the can. I still used the stock quick connects at the motor with covered hose clamps. Super pleased with the finished product.
Here are some pics of the finished product on a friend's car...
[IMG]local://upfiles/85500/08EC858A8D3C4575AF773B63D9B3A1FA.jpg[/IMG]
[IMG]local://upfiles/85500/7B741B5E3F894B88BD5D107A579832BE.jpg[/IMG]
Summit Racing:
ORIGINAL: A1SALEEN
WELL CRAP.... I guess i should check mine no to i thought it was just my friends doing it but now i car see this isn't the case ... so yeah where can we get the catch can?
http://www.steeda.com/products/steeda_oil_separator.php
lincolnshibuya
12-08-2015 04:37 PM
