Best way to remove the GT emblem!
RE: Best way to remove the GT emblem!
It's just double sided body tape. I removed my rear emblem with some fishing line (or other small strong twine). Run it between the emblem and the body panel to get it off.
I'd recommend going to the local auto parts store and getting some remover for the remaining tape on the body. That stuff is really hard to get off w/o some type of chemical remover.
NO..ther are 2 pin holes in the fender ..you can access them if you take the wheel well off..
You will need to fill them are replace the badge..with something else...
Sucks i know..
Sucks i know..
ORIGINAL: Sherwood06GT
I think the holes won't be a problem because I want to put the "Powered By Ford" emblem on in it's place. Right under the Supercharged emblem. [8D]
ORIGINAL: Mustang3GT07
Yea there are holes i was just about to ask if your taking off your GT emblem what are you going to replace it with? (hopefully not a cobra emblem)
Powered By Ford emblem! The Scott Drake all metal, very cool emblem! [8D]
