Problems in the rain
Old 12-03-2007, 08:06 PM
07BLACKGT
Default RE: Problems in the rain
If it only happened on that one trip then I bet the overdrive was turned off.
Your girlfriend could have possibly hit it when she got in, or you accidentally pushed it when putting it in drive. (it's located on the end of the gear handle, in case you didn't know)
Turning off overdrive puts you in 4th gear instead of 5th (I think.)But I know turning off overdrive slows you down when going down a hill, and it makes the rpm's a little higher so that could have been the different noise you weren't used to.
I have to go over a big mountain every day so I usually turn mine off when going down it so I don't have to ride the brakes.
Hope this helped!
07BLACKGT is offline
Old 12-04-2007, 09:50 AM
mattw30030
Just because I've heard so many problems with these cars in the rain, I would check for any leaking. I've had some weird stuff happen in the rain with the electrical, and the problem seems to be water spilling over and entering the car at some unknown spot. There is a compartment on the passenger side kick board area. Take that panel off, and stick your hand down through there and under the carpet, so you can feel the padding. If it's wet, you have water dripping on that fuse box right there. My car is at the dealer now for the third time due to this.
mattw30030 is offline
Ken_in_d
04-15-2016 02:25 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: Problems in the rain
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
