Sponsored by:
Sponsored by:
replacing the mustang guages, easy?
Old 12-07-2007, 09:07 PM
akumaky
akumaky's Avatar
Default replacing the mustang guages, easy?
I want to replace my mustang guages with ones with a white face. Would it be hard? oe do i need a body shop or some other place to do it? should be plug and play right?
this pic is what i am refering to:
akumaky is offline
Old 12-07-2007, 09:27 PM
howarmat
s197 Junkie
howarmat's Avatar
Default RE: replacing the mustang guages, easy?
its easy to do. All you have to do is remove the 4 bolts and unhook the wire harness and remove the cluster...once that is done you can pope the plastic top off and put the white faces it.
howarmat is offline
Old 12-07-2007, 09:30 PM
bmk
bmk's Avatar
that is MyColor FYI.. not an aftermarket gauge set
bmk is offline
Old 12-07-2007, 09:39 PM
akumaky
akumaky's Avatar
ORIGINAL: howarmat
Thanks a lot howarmat. One more question: After looking at my dash, i'm not sure how to get to the four bolts. Where do I start the disassembling?
akumaky is offline
Old 12-07-2007, 09:40 PM
akumaky
akumaky's Avatar
ORIGINAL: bmk
i have the MyColor options now. I'm looking to get a different guage set completely. I may not have understood what you are trying to say however.
akumaky is offline
Old 12-07-2007, 09:41 PM
howarmat
s197 Junkie
howarmat's Avatar
That is true if that is what you are looking for then you will have to do a mycolor upgrade, that is not the white face gauges.....2 different things
howarmat is offline
Old 12-07-2007, 09:44 PM
akumaky
akumaky's Avatar
ORIGINAL: howarmat
I have the MyColor already. I am not interested in it at all. I don't really like, nor use it. What I am actually doing is replacing my guages with Roush ones. I didnt want to say that because i'll get the "You're a worthless poser" messages instead of helpful responces.
So I guess my question is, Will it be plug and play to take out my GT guages and upgrade to the Roush guages?
akumaky is offline
Old 12-07-2007, 09:52 PM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
The bezel around the cluster will pull straight out. It's just clipped in. Then you can get to the bolts. If you need to pull the needles off without having an IDS start the car and take note of were the needles are when warmed up. Put them back on with the car running and at the same temperature. The speedo will be hard to get accyrate with this way though.
If these are the style you're looking at
PROMETHEUS PRIME is offline
Old 12-07-2007, 10:14 PM
akumaky
akumaky's Avatar
ORIGINAL: PROMETHEUS PRIME
You rock! I grabbed hold, pulled, and pop.. came right off. Then i saw the 4 bolts. Glad I will be able to do this on my own. thank you so much
Now i just need to wait until it arrives.
akumaky is offline
Old 12-08-2007, 02:48 PM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: howarmat
And you will need a guage needle puller as well.
They are sometimes included in the white face kit.
Getting the needles back on so they point properly
is another horror story..... []
157dB is offline
Diode Dynamics
28
05-26-2022 12:02 PM
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
Urambo Tauro
09-07-2015 12:47 PM
daytooday
08-11-2015 09:22 AM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: replacing the mustang guages, easy?
