Immediate Attention please!!! CAR TROUBLE
RE: Immediate Attention please!!! CAR TROUBLE
Car has 35,432......CAI only has about 5K on it. Is there a remedie to clean it or do I need to go buy the solution? Im in school so money is scarce, plus this trip will cost me about 150 down and 150 back
if you haven't changed your fuel filter and you regularly run it low then that would certainly be the cause. I would change out the filter first and foremost. Especially if it has never been done, I have had similar symptoms in a car that had a clogged fuel filter.
ORIGINAL: ezell504
What is a plug wire?
ORIGINAL: Black05StangGT
i'm thinking it may be a plug wire...seems that it could be the most likely culprit...
ORIGINAL: Stoenr
I would think he would be tripping a few DTC's, anyone else? Random misfires, or multiple.
ORIGINAL: ezell504
ORIGINAL: ezell504
ANd just a useful peice of info, My car actually ran harder before I had the cylinoid change! It felt as if it were tuned compared to now!
Well, if you had a tranny problem, there is a very good possibility that the car was reprogrammed--this could explain your hesitation if you have a cold air intake running on a stock tune.
