Oilcap Gone? Am i in trouble? PICS HELP
RE: Oilcap Gone? Am i in trouble? PICS HELP
Get one at the dealer or hit a junkyard. I doubt the oil is contaminated but it's cheap insurance and piece-of-mindto change the oil and filter.
It should be fine. If allowed to remain open for a while, it could be an avenue for moisture to get into the oil from the air. Turn it into that yellow peanut butter looking stuff. Unless a chunk of gravel road got up into there, it should have received nothing worse than a little dust.......nothing the filter can't take care of.
we swapped oil at the track one day, and a lot of things went wrong with a friends car right as I put the last quart in...needless to say, we ran over to help, and forgot about the cap.
I made a pass, and got an oil light at the end.
But cehcked it, and put the cap right back on, and it ran perfectly...
ORIGINAL: ModernMuscle
Did he slosh oil out or did a sensor just pick up that it was no longer a closed system?
ORIGINAL: 28HopUp
When you get a replacement cap, be sure to tell the clerk that you need a "710" cap.
I would be wary of putting foil over it. A motorin good condition and with the PCV system working as it should, the valve areas should be running at a lower than atmoshperic pressure, or in other words, it will be sucking. Foil isn't that tough and might break up allowing bits of metal foil into the motor.
A lightly oiled rag is best, with a clamp round it to keep it taut.
ORIGINAL: 28HopUp
