Question regarding tranny swap on a GT
A friend of mine told me to look into this...
Will it be ok or have advantages to swap the OEM TR-3650 Manual tranny for this
http://www.ddperformance.com/05-08%2...peed%20Kit.htm
its a T56 btw...
its a T56 btw...
RE: Question regarding tranny swap on a GT
ORIGINAL: s2k
can you post a pic of you car?
It sounds sweet by looking at your sig.
I am more interested in knowing if it will indeed be better, in all aspects, like highway rpm, low end power, city driving, MPG, etc.
I think we have a 10t, but I am taking this info out of my *** so dont trust me too much...
We need someone with knowledge here....
I thought a 6-speed would be better because of the extra gear? That extra gear allows you to run a lower final drive ratio, like 4.30 and shorter, while still having great highway speed.
Mustang GT TR-3650 = 10 Spline.
GT500 TR-6060 = 26 Spline.
Many of the SC and Turbo cars have snapped the 10 spline with Slicks and an aggressive clutch.
Mx, go ahead and call the ddperformance number, they were very helpful in answering all the questions I had about the swap. The big advantage, as Gene points out, is that the 6060 can handle more.
Ohnoesaz, the 6th gear is the same as our 5th, it's 0.62, so the highway rpm's won't drop with a swap. When I called ddperformance, if I understood them correctly, they said there are no conversion kits out there to put the 0.5 6th gear in.
Sleeper2
Sleeper2
ORIGINAL: sleeper2
Sleeper2
Sleeper2
I would like added power, andlower highway rpm's, they told me that the t56 was the better option...
