HELP!! just installed a bbk intake and a light came on...
RE: HELP!! just installed a bbk intake and a light came on...
make sure you have the maf in correctly. if the air goes through it backwardsit wont work properly. there may be an arrow molded into it to show air flow direction. check anything around the filter and tube area that may have gotten bumped and unplugged.
thanks for your help guys. but i just took it off i didnt wanna mess anything up. im gonna go to apex motorsports tomorrow and try to get a tune for it. does anyone know how much they run for?? or which one i should get?
ORIGINAL: sexyredfire
whats the difference between a dyno tune and an ordered tune?
Just go to brenspeed.com or bamachips.com and order either a sct or diablosport tuner with the tunes from them. Both are awsome. I went with bamachips because i like the tunes they do with the diablosport tuner where as brenspeed does really good tunes with the sct. Its w/e you want!
If you did indeed install everything correctly, then you were running too lean and it is a good thing you yanked the plug and put everything back. You can't believe something from someone that wants your money and will tell you anything to get it.
Make sure you connect all the cables right..
I got a check engine light when I connected the MAF sensor cable into the CAI but didnt "click" the red tab on the connector back in tight enough..(hope that makes sense..)
Other than that.. wait for that tune..
wait so are you saying i cant get one of those tunes like diablosport or sct at a mustang shop? sorry to keep asking questions, im new to mustangs.i drove an import before the stang.....
