SUSPENSION DONE PICS!!!!
#21
RE: SUSPENSION DONE PICS!!!!
ORIGINAL: thewarmachine
Hey, slvrstang, is it really necessary to use that spring compression tool to get springs on and off the struts? I'm getting front Roush springs and struts, but I don't have a spring tool. I was thinking of using some nylon rope to compress them....you know,...rig a loop to pull the rope back through like a pulley for some more power. Figured I could do this to both sides of the spring to get it compressed enough.
#22
ORIGINAL: slvrstang2007
Only problem now is I have a thunk noise when I shift from 1st to 2nd gear after the car has been driven for a while, anyone have any thoughts on this, I put the car back on the lifts to see if anything was rubbing but everything looks ok, so I'm puzzled, but other then that I love it!
Tom
#23
ORIGINAL: Argonaut
Yes, you have to have a spring compressor. I can't imagine your rope pulley idea working, these springs are strong! I went to Autozone and 'rented' one. It was a kit that consisted of two C-Clamp looking pieces, one for each side of the spring. There are locking pins to prevent slippage, something that could ruin your day. The top of each clamp has a nut you turn with a wrench that forces the two ends of the clamp together and compresses the spring. You may not have to use it to get the new springs back on the strut, depends on the spring. The Eibach-Pro did not require, its just short enough that you can get the top nut of the strut started without the compressors.
#26
Ya definatly going to check my pinion angle today, definatly dont want to snap the u-joint, thanks for the info. Any yes I think a spring compressor is necessary, someone said you might be able to use a floor jack but I dont know how that would work, so just rent one for a short time it only took me 20minutes to get them finished. good luck!
#27
ORIGINAL: Pwny
That thunking noise means you have the risk of snapping a u-joint. Your pinion angle must be way off so check it ASAP!
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
