Transmission question!
12-18-2007, 09:02 AM
I was wondering the max amount of horse power these stock 5 speeds will handle and for how long.... And also what are you guys with a lot of power launching at.. Are these rearends pretty strong??
12-18-2007, 09:10 AM
RE: Transmission question!
this is all i have on the manual transmission, as
far as torque capacities
[IMG]local://upfiles/37808/D78622470A704142A537D8088E06DAEE.jpg[/IMG]
12-18-2007, 09:19 AM
Well lets hope it can hold more then 360lb trq.. Im at 550+
12-18-2007, 09:43 AM
you'll be fine
12-18-2007, 10:24 AM
Me thinks 610 rwhp + TR3650 + Slicks = Broke
Best Option for a street tranny is a Viper Spec T56 or TR6060.
The stock input shaft on that 3650 is definately on borrowed time.
But its only the weakest link.
If you plan on that tranny having a prayer of living I suggest a "fusabile link" like Nittos.
12-18-2007, 10:34 AM
Last time I was at the track I was cutting 1.7's on ET streets..... That was when I had 460 rwhp..Just wanted to know what I was up against with the new power plant....
12-18-2007, 10:44 AM
Clutch will go first, when you replace it, look into the 26 spline input shaft for a little extra strength.
12-18-2007, 10:50 AM
Quote:
ORIGINAL: D_Gusler
Already have a stage 3 duel friction in her!
12-18-2007, 10:54 AM
once you replace everything from the
flywheel back, you should be ok
12-18-2007, 10:57 AM
So no one is making a rebuild kit that is stronger for our trannies yet? I was hoping someone would.
