What is the bolt torque for front & rear calipers?
I am going to throw on some drilled/slotted rotors tomorrow and i need to know the torque specs from the caliper bolts.
TacoBill says 85lbs front and 76lbs rear, I would just like to know if anyone has this info handy and can either confirm or deny those figures?
Thanks in advance.
Thanks in advance.
RE: What is the bolt torque for front & rear calipers?
I asked the service guy I went to high school with and he confirmed those numbers! Tacobill would not steer you wrong!!!!!!!!!!!!!!! here is a link to his even though you already have seen this..https://mustangforums.com/m_3083874/tm.htmLater J
SECTION 206-00: Brake System — General Information[/align]
2007 Mustang Workshop Manual[/align]
SPECIFICATIONS[/align]
Torque Specifications
Description
Nm
lb-ft
lb-in
Brake caliper boltsa
33
24
Front brake caliper bleeder screw — 4.0L SOHC and 4.6L (3V)
Front brake caliper bleeder screws — 5.4L
18
13
Master cylinder brake tube fittings
17
13
Rear brake caliper bleeder screw — all vehicles
http://www.fordracingparts.com/Musta..._FR500S_v1.pdf
76 is confirmed for the rear caliper mount bolts. See above.
Don't confuse these big mount bolts ( called rear brake caliper anchor plate bolts in Ford-speak) with the caliper slider pin bolts!! Those caliper pin guide bolts only get 24 Lb-ft.
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
