Gauges? UPDATE PICTURES
#31
RE: Gauges? UPDATE PICTURES
Nice job on those gauges. I've seen two gauges stuck in that space, I'm trying to figure out a way to stuff 4 in there (2 over 2). It will be tight, I'll have to file down some of the trim rings.
Sleeper2
Sleeper2
#33
ORIGINAL: marcuskeeler
Yoinks !! [&:] Me no touchy Air Baggy. Me got fat fingers like Pig trotters
"I need smaller fingers damnit!"
it is a rather easy removal tho.. just sounds crazy.
I have a little motorized screwdriver i use to remove all the screws/bolts, and i can get the center dash piece out in like 10 minutes at the most..
#34
ORIGINAL: sleeper2
Sleeper2
Sleeper2
Cubs17 - yeah i was.. before i cut into it i just kept telling myself, "its a new car, and if i need to i can buy the new panel again"
#36
ORIGINAL: Shredder
far from.. you have to remove the passenger side airbag to remove it..
remove battery negative terminal then wait 30 minutes to make sure there is no charge in the airbag sensor
remove 4 screws at the bottom of the glovebox, remove glove box
remove 2 bolts holding the airbag in, reach in from the inside and push all around the outside to detach little clips, DO NOT pull on the airbag panel, you can seperate the dash trim from the airbag some and your dash will be uneven, like mine is now lol.. i still gotta find out how to fix it.
pull the dash trim from the instrument gauge cluster outwards
remove 4 bolts holding the center dash piece in..
was harder to figure out than it was to actually do.
There's a ton of stuff that can be monitored through the diagnostic port. this gauge displays long and short term fuel trims, fuel pump duty cycle, both cylinder head temps, both 02 sensors, injector pulse width, MAF counts, throttle position and of course any sensor on the car like coolant temp, air temp, etc.
There's no oil temp sensor or even a traditional oil pressure sensor, but I could always add those sensors and attach them to this gauge. It will also record whatever parameters that are displayed after 50% throttle is applied for up to 60 seconds I think. That's what's happening in the above picture, i was recording mph and horsepower.
#37
I think you guys just saved me some cash! I was thinking about a wideband to supplement my Aeroforce, but seeing that 850mv equals 11.5 AF and 900mv is richer I should be safe if I'm putting up anything above thisvoltage.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
treesloth
09-28-2015 07:03 AM
