Sponsored by:
Sponsored by:
C&L in, impressions
Old 01-08-2008, 05:10 PM
jmanpatsfan
jmanpatsfan's Avatar
Default C&L in, impressions
Installation was a piece of cake, like you all said it would be. Tune upload (93 Brenspeed) no issue. When I took it for a drive, I may have been expecting too much, but I didnt really notice a big difference, but there was an extra jolt when you step on it. Exhaust does not sound any deeper. I really thought when people said "throttle lag" it referred to that jump off the line. I still appreciate it and I'm happy. (You were supposed to press cancel when it said "Keep previoulsy entered options," right?)
jmanpatsfan is offline
Old 01-08-2008, 06:17 PM
harraid5711
harraid5711's Avatar
Default RE: C&L in, impressions
i had the same experience......
harraid5711 is offline
Old 01-08-2008, 06:19 PM
Fletch
Fletch's Avatar
Did you put 93 gas in it?
~Fletch~
Fletch is offline
Old 01-08-2008, 06:40 PM
jmanpatsfan
ORIGINAL: Fletch
~Fletch~
Of course.
Old 01-08-2008, 06:53 PM
howarmat
s197 Junkie
howarmat's Avatar
hmm...talk to brenspeed....i would say you should notice a great deal of difference with the addition of a cai/tune coming from the stock setup
howarmat is offline
Old 01-08-2008, 07:17 PM
Argonaut
Argonaut's Avatar
When I first installed a CAI and 93 tune I felt that the difference in horsepower was noticeable but not dramatic (I think some folks are a bit prone to hyperbole on this). To me the bigger change was the improvement in throttle lag. Here is an example of what I mean: with stock tune if you put the car in neutral and blip the throttle, there was a clear lag between the action and the result, the engine just didn't rev very fast. In actual driving I thought this was the most disappointing aspect of the car. My old 93 Nissan Pathfinder has better throttle response. But after installation of the CAI and tune all was well, much more what I wanted. Now when I nail the throttle the engine responds nearly instantly, much better than stock. If your car didn't exhibit this change than I'd think either the Tune is wrong or it didn't get downloaded to the car properly.
Argonaut is offline
Old 01-08-2008, 07:51 PM
dr350rider
dr350rider's Avatar
It's been a couple of weeks since I uploaded my new tune so I've already started to forget. I think the SCT asks if you want to change any parameters and there you would hit cancel, unless you want to mess with your tune. Then I think it asks if you want to keep "previously entered options". I think you are supposed to hit select for that one. You might just try running through the upload process again.
dr350rider is offline
Old 01-08-2008, 08:06 PM
ShadyNinja
ShadyNinja's Avatar
:0 maybe try a tune from a different tuner?
ShadyNinja is offline
Old 01-08-2008, 08:13 PM
howarmat
s197 Junkie
howarmat's Avatar
If you car is not throwing codes then the tune is loaded....with a C&L it usually will through a code pretty damn quick without the tune
howarmat is offline
Old 01-08-2008, 08:20 PM
ShadyNinja
ShadyNinja's Avatar
ORIGINAL: howarmat
true!
but when I was stock I installed the diablo cookie cutter tune and was like wow thats better, then got the 93 tune from doug and got the same wow improvement as the stock to diablo made.
Quick Reply: C&L in, impressions
