Camber Bolts and Adjustment
I plan on installing my Roush front springs and struts this weekend, but I was wondering what to do about camber adjustment.
Is the camber something I can adjust myself with camber bolts, or is it something I should let the tire shop do.
I'm also getting tires mounted on my new rims Friday, so maybe if I get the springs/struts done before I get the tires done they can adjust my camber.
How exactly do camber bolts work?
I'm not familiar with the front suspension, but I have seen TacoBill's spring installation post.
Do they replace factory bolts or are they used in addition to the factory strut bolts?
Also, if I do get the tire shop to adjust my camber, can they do it with their tools, or would I need to purchase camber bolts prior to visiting the tire shop?
Thanks in advance for all the info.
RE: Camber Bolts and Adjustment
since u r getting it done this weekend, call the tire shop and c if they have the correct camber bolts in stock. they can install with the alignment and adjust to specs. I had mine set at -.75 degrees.
I read somewhere that it's a good idea to wait a week or two after spring installation before getting the camber adjusted so the springs have time to settle some. Does this sound right?
ORIGINAL: thewarmachine
Your suspension (springs) will settle after any work done on it.
