Question about the CDC Sequential Taillight Kit
Sorry if this is in the wrong thread, I'm new to this site.
So I was thinking about buying this for my '08 V6:
https://mustangsunlimited.com/itemdy00.asp?T1=DA74+01
Does anyone know if this 1-2-3 light sequence also applies when you use your turn signals? I couldn't find that on any of the site that carry this product. I thought somebody here might know. Thanks.
RE: Question about the CDC Sequential Taillight Kit
http://www.classicdesignconcepts.com...tail&p=120
CDC has engineered an ALL NEW Sequential System for the 2005-8 Mustang...the Dynamite Sticks Sequential System. This dynamite design requires no core, no splicing and no harness; the results high tech lighting to your rear end with simplified installation. This advanced engineered system uses Ford OEM connectors with a preprogrammed microprocessor that controls timing for optimum performance. Standard with reverse circuit protection with voltage regulation, also CDC’s sequential system has physically sealed the package that protects electronics from moisture that will enter your trunk. When the brake is applied the lights will sequence once and then stay solid.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
