Sponsored by:
Sponsored by:
Oil, from regular to synthetic?
Old 01-19-2008, 08:16 AM
  #21
07 Stang
07 Stang's Avatar
Default RE: Oil, from regular to synthetic?
This past Dec. I had the dealership change the oil and put synthetic in. It was a little more than a regular oil change, but I don't mind spending more if it's going to help make my car last longer.
07 Stang is offline
Old 01-19-2008, 08:37 AM
  #22
mpatilla
mpatilla's Avatar
It is weird to hear that Ford doesn't recommend the full synthetic. I don't understand why. I haven't had my first oil change yet, but I am definitely planning on using the full synthetic. Always have in other cars (except for my '66 Galaxie, where I just use a Havoline 10w30 and change once per year, which is about 2000 miles). I guess I will be prepared for them to try and talk me out of it!
mpatilla is offline
Old 01-19-2008, 08:51 AM
  #23
Chris07GT
Chris07GT's Avatar
Ford offers a synthentic blend (that's what comes in the our cars) and a full synthetic (which you pay a little extra for). I switched to full synthetic at 1,000 miles and now I use Fords full synthetic oil.
Chris07GT is offline
Old 01-19-2008, 09:01 AM
  #24
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Well here in Michigan it is offered at the dealer (you have to request it) and they see nothing wrong with using it!
Now I am not saying that I get it done at the dealer (have been changing it myself since I bought it) but I am good friends with the service manager at Rochester Huntington Ford and they do offer it!. I would use Ford motorcraft filters as well.....they make a quality filter! Mobil 1 makes one as well.....K&N....etc
ORIGINAL: SoFlaGT
ORIGINAL: mygt500
Ford uses full syn in the oil changes from the dealer. Synthetic oil meets and /or exceeds any requirements the maunfacturers require for motor oil! I have been using that since the first oil change. J
Not when I got my first oil change! They tried everything they could to talk me out of going full syn.
I guess I'm going to do my own from now on ... can get the oil (Mobil1) at Costco pretty cheap. Just have to figure out what filter I want to use.
[/align]
mygt500 is offline
Old 01-19-2008, 04:32 PM
  #25
VistablueDrew
VistablueDrew's Avatar
Well since the shop that works on my car has the 2nd fastest mustang in the country and they use the ford synthetic blend, I will stick to that.
VistablueDrew is offline
Old 01-19-2008, 04:43 PM
  #26
Burnsy
Burnsy's Avatar
The best filter on the market is the ford racing filters, but the motorcraft is second and is a lot cheaper. If you want the best, pay for a case of 12, but the motorcrafts are pretty damn good themselves.
Burnsy is offline
Old 01-19-2008, 04:53 PM
  #27
deekum1627
deekum1627's Avatar
i used motorcraft the 1st oil changenow im goin to switch toroyle purpleand K&N oil filteror should i used the ford oil filter???
deekum1627 is offline
Old 01-20-2008, 09:40 AM
  #28
VistablueDrew
Royal Purple I heard was no good for the mustangs. The shop I go to said to only use Motorcraft synthetic blend.
Old 01-20-2008, 09:50 AM
  #29
GidyupGo
GidyupGo's Avatar
ORIGINAL: VistablueDrew
I'll never use RP again. It "disappeared" when I used it in my 4.6l truck.
GidyupGo is offline
Old 01-20-2008, 03:47 PM
  #30
Burnsy
Burnsy's Avatar
ORIGINAL: deekum1627
From the comparisons that I have seen, the motorcraft filter is better than the K&N and is cheaper...
Burnsy is offline
Quick Reply: Oil, from regular to synthetic?
