Stupid BMR LCA question
Ok I have a question.
I have the BMR LCA's and I'm going out to get some Silicone grease. But the thing is...ummmm....where do I put it on the Lower Control arms? I see that there are like two little nuts on them, do I put it in there?
RE: Stupid BMR LCA question
Yep go to Sears or auto parts store and pick up a mini grease gun like this, it usually comes with alithium grease tube.
http://www.northerntool.com/webapp/w...mnosearch=true
you put the greese inbetween the poly and the metal that holds the poly
1. get greese gun
2. get greese
3. put greese into greese gun
4. connect the greese gun to the zerk fitting
5. pump the grease gun
6. disconnect the greese gun
7. repeat steps 4-6on other poly bushings
1. get greese gun
2. get greese
ORIGINAL: Ford_Dude
1. get greese gun
2. get greese
1. get greese gun
2. get greese
Greese me up, Scotty.
Use the silicone on the bushings prior to assembly.
Use the zerks to apply grease after assemble for a
squeek free rear end.
[IMG]local://upfiles/69445/0B0227BF9286498DBAA5104FD30592A9.jpg[/IMG]
