Sponsored by:
Sponsored by:
A good gas tip.
Old 01-18-2008, 11:50 AM
Harley76
Harley76's Avatar
Default A good gas tip.
The story.[/align][/align]A couple of weeks ago we had a warm spell here in Michigan (50plus degrees) and being the old Harley guy that I am, decided to take my old Iron Head out for a ride. Well to make a long story short, I stopped at a gas station for a cup of coffee and while sipping my brew spied a young man pumping gas into his Mustang GT. I went over to have a talk and brag about my GT and as soon as I got there he hung up the pump and I noticed he only put $10 of 93 octane in and that at this station the pumps where the single hose type for all 3 octane levels. This is the type of gas station I try to avoid like the plague when on the Harley as I only have a 3.5 gal. tear drop tank and out of habit will avoid it in the GT if I can. So I explained to him why he was making a mistake and thought I'd pass it on here too.[/align][/align]Why its bad.[/align][/align]If you are buying gas at a station that does not have a dedicated hose for each octane you are putting at least point .3 gals of gas from the last octane level used into your tank. On our cars this does not make that much of a difference when we fill up (from 93 to 92.8). If your running low on fuel however and only put $10 in this will make a big difference in octane drop. You can imagine what this does to the 3.5 gal tank on my Harley. Here is a training page for weights and measures that will explain the .3 gals in the hose on page 2-10.[/align][/align]http://ts.nist.gov/WeightsAndMeasures/Training/upload/(302)ch2.pdf[/align][/align]Moral[/align][/align]If money is a little short and you can't fill up, find a dedicated pump.[/align][/align]Long winded bastard ain't I,[/align]Harley[/align][/align]
Harley76 is offline
Old 01-18-2008, 11:53 AM
ink003
ink003's Avatar
Default RE: A good gas tip.
i never would've thought of that- definitely makes a difference, and especially if one has a tune running. thx for the advice harley76!
ink003 is offline
Old 01-18-2008, 12:01 PM
white07
white07's Avatar
I never had a explanation behind it but when I see pumps like that I always figured you could be putting a lower octane gas into your car cause its in the line. Since I have a tune for 93 putting 87 in can be bad news. Thanks for the info.
white07 is offline
Old 01-18-2008, 12:26 PM
Tracedaddy
Tracedaddy's Avatar
Good point. Thanks.
Tracedaddy is offline
Old 01-18-2008, 12:38 PM
viperrmk
viperrmk's Avatar
Cool never knew that. Thanks
viperrmk is offline
Old 01-18-2008, 12:53 PM
Ultrashock
Ultrashock's Avatar
All of the gas stations in my area have a single pump with the 3 octane buttons. =[ This does make sense though. I havn't had any problems with the 93 tune so far though.
Ultrashock is offline
Old 01-18-2008, 01:04 PM
Full Throttle
Full Throttle's Avatar
ORIGINAL: Ultrashock
yeah same thing around my area (ontario). I don't think that I have ever seen a pump with hoses for each octane level.
Full Throttle is offline
Old 01-18-2008, 01:27 PM
schapman
schapman's Avatar
I cant see it making a differencein a large tank. If im running a 93 tune my car isnt going to blow up if the gas is only 92.8. Thecomputer will adjust the timing if its even needed.Also, the octane only matters if your runnin your car hard. I could run 89 octane gaswith my 93 tune if i was just on a long trip on the highway and had it on cruise control.
schapman is offline
Old 01-18-2008, 01:36 PM
Ultrashock
Ultrashock's Avatar
I do remember seeing 1 pump per octane a long time ago when I was a kid. I don't see them anymore around here with all the new stations...even older ones. Im with shapman, I don't think its so significant that it will do any real damage. However, with the 3.5 gal situation...it could be a different story. I just say that acetone video on how it raises mpg when added 2 oz/10 gal. Not to get off topic, but does anyone REALLY believe that would work? [&:]
Old 01-18-2008, 01:41 PM
TAMPAGT07
TAMPAGT07's Avatar
The 93 represents the minimum octane rating.Usually the ratings are actually slightly higher.I believe even if your octane dropped to 92.8, this should not be a problem. Hopefully the inspector(s) in your area are doing their jobs and monitoring the gas pumps.
TAMPAGT07 is offline
Quick Reply: A good gas tip.
