stereo removal - double din?
iwanna takemy stereoout, i think its oem. is that double din? can i remove it safely or should i take it to an audio store?
im tryin to put in a small-ish screen, and a new radio with built in hd receiver, sound good?
its an '06 mustang, v6, 4.0 if any of that matters but i dont think that actually matters to the radio does it.
[IMG]local://upfiles/88950/82B597480C6C49DCAE79E5AFD94755A5.jpg[/IMG]
RE: stereo removal - double din?
Item
Part Number
Description
7E391
Selector lever bezel
W705314
Floor console finish panel screws (2 required)
044D90
04608 RH/ 04609 LH
Instrument panel finish panels
Removal and Installation
All vehicles
[ol][*]Apply the parking brake.[/ol]
Vehicles with manual transmission[*]Place the gearshift lever in the NEUTRAL position.
[ol][/ol][*]Unscrew the gearshift lever ****.
[ol][/ol]
[ul][/ul][*]Remove the gearshift lever **** and boot.[*]With a non-marring tool, lift the gearshift lever boot retainer upward.
[ul][/ul]
[ol][/ol]
Vehicles with automatic transmission[*]Place the selector lever in the NEUTRAL position.
[ol][/ol][*]Remove the selector lever bezel.[*]With a non-marring tool, lift the selector lever bezel upward.[*]Open the storage compartment door.
[ol][/ol][*]Remove the 2 floor console finish panel screws.
[ol][/ol]
[ul][/ul][*]Remove the floor console finish panel.[*]Lift the floor console finish panel upward to release the retaining clips. #3 in pic[*]Disconnect the electrical connector.
[ul][/ul]
[ul][/ul]
[ol][/ol][*]Remove the LH and RH instrument panel finish panels. # 4 in pic[*]Pull outward on the instrument panel finish panels to release the retaining clips.
[ul][/ul]
[ol][/ol]
[ul][/ul]
[ol][/ol]
[ol][/ol][*]To install, reverse the removal procedure.
[ol][/ol]
Item
Part Number
Description
W705314
Instrument panel center finish panel screw (6 required)
Instrument panel center finish panel electrical connectors (5 required) (part of 14401)
[ol][*]Remove the floor console. For additional information, refer to Console — Floor in this section.[/ol][*]Remove the 6 screws and remove the instrument panel center finish panel.[*]Disconnect the electrical connectors.
[ul][/ul]
[ol][/ol][*]
NOTE: Be sure that all climate control assembly electrical connectors are securely fastened before installing the center instrument panel finish panel.To install, reverse the removal procedure.
Item
Part Number
Description
W705314S
Audio unit screws (4 required)
Audio unit electrical connectors
18C815
Audio unit
Remove the 4 screws and the audio unit.[*]Disconnect the electrical connectors and the antenna lead-in cable.
[ul][/ul]
[ol][/ol]
jwog666
12-27-2021 08:09 PM
