Sponsored by:
Sponsored by:
Rear Axle Mis-Allignment?
Old 01-23-2008, 07:08 PM
jmk3
jmk3's Avatar
Default RE: Rear Axle Mis-Allignment?
ORIGINAL: dmhines
After my Roush Springs ... my driver sidewheel sticks out 3/4 inch further thanthe passenger side when measured via 1/4 panel lip. I have an adjustable panhard bar to put in once the weather gets warmer to split the difference and get it back in the middle.
Holy cow 3/4" I put my roush rears on & it was colser to center than stock, when the car goes up & down it chages hence the interest in the watts link. I can't figure oe it could go 3/4" out from a 1" drop, it must have been way off from the factory. You didn't measure with the car on jack stands did you?
jmk3 is offline
Old 01-23-2008, 08:13 PM
dmhines
dmhines's Avatar
I measured on the ground ... keep in mind that it's 3/4 further out to the driver side ... So I need to move it 3/8 inch towards the passenger side to center ...
dmhines is offline
Old 01-23-2008, 08:19 PM
pascal
S197 Section Modder-ator
pascal's Avatar
You guys have the circle track option on your Stang.
Actually, the assymetry is even worse with the old leaf spring set-up.
All this isn't that uncomun.
pascal is offline
Old 01-23-2008, 08:23 PM
Stoenr
Stoenr's Avatar
If you did not mention to the shop that you had the adj panhard bar, they probably wouldnt look twice in the rear. Typically nothing is adjustable from factory.
Also, you are lowered and you did not get adj LCA's? Why not? did you get an adj upper link? Pinion angle may need to be adjusted via the adj LCA or upper.
Also, did you get new camber bolts or plates to adj the front properly after lowering?
Stoenr is offline
Old 01-23-2008, 09:42 PM
ink003
ink003's Avatar
ORIGINAL: Stoenr
i didn't get the adj. lca's after speaking with fast toys - instead, we decided on the relocation brackets and the regular lcas since the car is a dd and i won't be hittin the strip any time soon. i hope this was good advice [&:] i did buy camber bolts, but the shop i took the car to for the alignment didn't need to install em - all the numbers came out ok. here's the list:
front-
cross camber: 0.1 degrees
cross caster: 0.4
cross sai: -0.3
cross turn diff. set back: 0.15
wheelbase difference: -0.33
track width diff: 0.49
rear-
cross camber: 0.2 degrees
total toe: -0.08
thrust angle: 0.00
set back: -0.18
axle offset: 0.00
track width: 63.8 in.
i really hope i'm not missing something here [>:] i can certainly adjust the phb myself to correct for the minor mis-alignment, but did they not check the pinion angle? do any of these numbers reflect that? do i need adj. uca's? i thought those were more optional than absolutely necessary... ahhh, help!
ink003 is offline
Old 01-24-2008, 06:30 AM
ink003
ink003's Avatar
bump for some more help [&:]
ink003 is offline
Old 01-24-2008, 09:26 AM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: ink003
hey guys
so, i had a bunch of suspension goodies installed last week, and since then i've taken the car to a reputable shop to get it alligned. just out of curiosity, i decided to check the rear axle allignment the other night, to make sure it was even (i have a new phb installed). according to my calculations, it looks as if the driver's side is about a 1/4" off from the passenger's side.
questions:
Side to side out or
front to back out?
Side to side out - adj panhard bar
Front toback out - Adj LCAs.
157dB is offline
Old 01-24-2008, 09:29 AM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: jmk3
ORIGINAL: dmhines
+1
I dropped my rear with the Roush springs and didnt need an
adjustable panhard bar. It even put it closer to the center
as it was out from the factory.
157dB is offline
Old 01-24-2008, 11:18 AM
Simon1
Simon1's Avatar
ORIGINAL: ink003
ORIGINAL: Stoenr
front-
cross caster: 0.4
cross sai: -0.3
rear-
total toe: -0.08
thrust angle: 0.00
set back: -0.18
axle offset: 0.00
I went to three different shops and asked about pinion angle adjustment. They looked at me like I was crazy. Iborrowed a gauge from my buddy and checked my angle and it was just fine.
Simon1 is offline
Old 01-24-2008, 01:12 PM
HDFINDER47
HDFINDER47's Avatar
After Eibach Pro kit installation mine alsoshifted rear tires (1/2" to the driver's side): Laseralignment numbers show everything is within specs and it rides/steers fine so am leaving alone for now. If it ain't broke ..............
HDFINDER47 is offline
Quick Reply: Rear Axle Mis-Allignment?
