Those who lowered how far did you go
RE: Those who lowered how far did you go
ok so it seems i need to pick up this lowering package, a rear sway bar, and possibly a panhard brace? i already have lca, uca and shocks, and springs, so after those upgrads i should be good to go.
I run the Ford Racing 1.5" drop springs without any other suspension mods and I have no problems at all. I will be adding LCA's with relocation brackets, adj. panhardbar and brace, UCA and Tokicos.
Steeda Sport Sptings.. and very happy. I did not need an adj panhard bar.. but will probably get new dampers next year (I only drive about 7000 a year).
ORIGINAL: |UCF|chron
not how low but how extensive did you go with your lowering job ie just springs or new panhard, uca, lca etc. i ask because i have been eyeing this BMR package because it offeres a lot i dont have, only thing that overlaps are the springs. http://www.bmrfabrication.com/2005MustangPACKAGES.htm its the lowering package. so how many of you have gone this far when lowering. i also want to get a rear sway bar bc i dont even have one and i hear the differences can be huge.
BMR lowering kit, BMR billet aluminum lower control arms, BMR adjustable upper control arm (to adjust pinion angle), Tokico D Specs, and BMR tubular subframe connectors
