Stock Driveshaft Weight...WOW!
RE: Stock Driveshaft Weight...WOW!
ORIGINAL: 08Steeda
The one piece drive shaft will connect to the pinion gear at a different angle then the stock driveshaft. To compensate for this the adjustable LCAs are recommended. The Lower Control Arms (LCA) will need to be shortened to correct the pinion angle. Failure to do so will result in vibration at various speeds. The OEM pinion angle is between -2.7 and -3.
Pinion Angle OK
U-Joint Operational Angle OK
Going to try reclocking the shaft tomorrow morning.
My best guess is the "hum" Im feeling is gear murmur from the stock ring and pinion.
If so reclocking the driveshaft should help "tune" it to help cancel this.
I suspect this is why Ford uses a 2 piece with the 8.8".
Galactic
04-29-2019 02:56 PM
Luke9222
10-22-2015 11:55 PM
05, 50, bmr, bmrds005, difference, drive, driveshaft, ds005, fabrication, gt, mustang, s197, shaft, stock, weight
