Ticking noise... - Page 2 - MustangForums.com
Ticking noise...
Old 01-31-2008, 06:46 PM
Stangula
Default RE: Ticking noise...
could be any of the above things but imo i dont think its injectors cause they will do it at all times warm or not i think it is most likely valvetrain noise if you still have warranty take it to dealer they will replace for free and doesnt take long at all hydraulic lifters make noise when they leak because they arenot protecting the valve from botteming out so imo i think one of you lifters in leaking
Stangula is offline
Old 02-06-2008, 12:12 PM
mAnYsTyLeS
"i think one of you lifters in leaking" huh? Where the h*ll is the hydraulic lifter???
mAnYsTyLeS is offline
Old 02-06-2008, 12:55 PM
d_ames117
If you remove the valve cover you'll see the camshaft and the hydraulic lifters (the lifters push on the valves to open them). Hydraulic lifters are used to help prevent noise as well as to increase the life of the lifter and cam. They are filled with oil which helps them keep in contact with the cam lobe at all times as it rotates. Therefore, hydraulic lifters are silent. However, if they are worn or defective or old, they can leak oil if they sit for a while (even new ones if they sit long enough). This makes the lifters soft, and they don't spring back quickly once the cam lobe pushes on them. This creates a gap and the next time the lobe comes around it smacks into the lifter creating noise. Once the oil is warm, oil pressure will refill the lifter with oil, removing the gap, and lessening the noise. Not an issue if it goes away relatively quickly. If it takes a long time for the lifter to pressurize and then looses pressure quickly, might be time to replace the defective ones.
In your case, I wouldn't worry about it. Just a combination of cold temps and the car sitting. It's normal.
Dustin
d_ames117 is offline
Old 02-07-2008, 12:49 PM
mAnYsTyLeS
ORIGINAL: d_ames117
Dustin
Excellentexplanation...thanks! Also, just in case it matters...I hadSteeda powder coated valve covers installed the same time as my Steeda delete plates. The noise was coming from my car way before the valve cover and CMCV deletes were installed though so I'm guessing that's irrelevant.
So far I'm leaning towards the problem beingthe really cold temps and my car sitting for more than 6 or 7 days. What puzzles me though is that wouldn't both sides of the engine make that noise then? Instead of just the left side near the fuse box?
Old 02-07-2008, 01:52 PM
OhioState87
OhioState87's Avatar
ORIGINAL: mAnYsTyLeS
Excellent explanation...thanks! Also, just in case it matters...I had Steeda powder coated valve covers installed the same time as my Steeda delete plates. The noise was coming from my car way before the valve cover and CMCV deletes were installed though so I'm guessing that's irrelevant.
So far I'm leaning towards the problem being the really cold temps and my car sitting for more than 6 or 7 days. What puzzles me though is that wouldn't both sides of the engine make that noise then? Instead of just the left side near the fuse box?
Is your noise the same that is talked about here and that I also have?
OhioState87 is offline
Old 02-07-2008, 02:22 PM
GidyupGo
ORIGINAL: d_ames117
Dustin
Yes. You may indeed have a collapsed lifter. If it is that, it will eat on a cam lobe which ain't good. Stethiscope time.
GidyupGo is offline
Old 02-07-2008, 04:10 PM
mAnYsTyLeS
ORIGINAL: OhioState87
No, but it's actually along the lines of what GidyupGo mentioned in that thread...
"I'm thinking PS pump or and probably the most likely, belts. They will make some weird noise. I had one once that made a sound like lifters. JUst a steady peck peck. Spray a little water on the belt when they are making the noise to see if it goes away or gets worse. Since it goes away when warm, I doubt it is fuel related. "
Can you guys just let me know how I can check this myself without bringing it somewhere. Also, take into account that I've never even changed my own oil. Thanks for your help!!
G
Old 02-07-2008, 04:35 PM
GidyupGo
Another thing I have done to eliminate belt noise is shoot a little WD40 on the belts while running. Carefully listen for any change in noise. If there is....BINGO!
GidyupGo is offline
Old 02-08-2008, 08:27 AM
d_ames117
Brake cleaner also works for this purpose. Although usually the belt will squeek. If the belt is ticking you may want to have it replaced as I'm not sure what could cause that.
To figure out if it's a lifter (and which ones) you can use an automotive stethescope and place it on the valve cover. If you don't have a stethescope, you could use a length of 2x2 and hold it up to your ear.
Dustin
Old 02-08-2008, 02:20 PM
mAnYsTyLeS
Sweet...I'll let you know how it turns out. Thanks!
Nick Oliver
04-27-2018 02:00 AM
69Volunteer
09-30-2015 10:39 AM
Sixer4Life
09-28-2015 07:05 AM
Shadow7874
09-24-2015 09:06 PM
Emblazoned
09-03-2015 10:45 PM
Featured Sponsors
