Cervinis or Ronaele Side Exhaust?
i was wondering, after hearing all the negative talk on the cervinis side exhaust ground clearance being a huge problem. Does the ronaele have the same problem? i figure i'll go with the entire cervinis kit, but if the ground clearance on the ronaele is somewhat taller, i figure i'd go with ronaele for the side exhaust.
thanks.
thanks.
RE: Cervinis or Ronaele Side Exhaust?
I doubt you're going to get an answer because the Ronaele stuff is so rare. The parts are actually purchased through Blow-By-Racing and produced by a company called Keanan. I have their side scoops and window scoops, and I can tell you that the quality is top notch.
I spent a lot of time deciding on my side skirts (3dCarbon) and I photoshopped several pictures trying to determine how much lower the side skirts made the car. I determined about 1"....but onceI installed them I found out they are even with the frame rails, exactly like the stock side skirts. In other words, there is no way to know how low they are unless you find someone who has them.
But aside from the side and window scoops, I think the Kaenan stuff looks pretty bad. It's not designed nearly aw well as the Cervinis stuff....although like I said the parts are top quality.
I don't really like side exhaust...but it is your car.
http://www.youtube.com/watch?v=sxDDD95PiFk
